Removing grout from tile face
Help! Ive just grouted a beige tile with black grout. I followed all directions on packages, i.e. set and dry times. I started to remove the grout and found taht it has stained/adhered to the tile face. The tile is glazed but with a slightly rough texture. I did not seal the tile before appyling the grout. Do you have any suggesting to clean the face? I tried to scrub and use bleach and Comet. Would you recommend muriatic acid and then seal? Will I need to regrout?
Grout removers exist. The link below is just a sample. The fast way to obtain a grout remover is call tile supply stores and ask for one. http://www.aldonchem.com/pr-grout-residue-remover.htm
