Wonderboard vs Plywood
Old 06-28-00, 10:38 PM
Guest
Question
I am replacing carpet in an entry way and dining area with slate tile. The subfloor is 3/4" plywood on waferboard I-beams 16" OC. The entry may see occasional water from tracked in rain/snow. What are the arguments for using 3/4" CDX or Wonderboard over the other? If I go with wonderboard 1/4" or 1/2"?
Old 06-30-00, 09:08 AM
Guest
Post
For floors use the 1/2 inch. Wonder board takes water excellent. I would use it.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by dirtydog:
I am replacing carpet in an entry way and dining area with slate tile. The subfloor is 3/4" plywood on waferboard I-beams 16" OC. The entry may see occasional water from tracked in rain/snow. What are the arguments for using 3/4" CDX or Wonderboard over the other? If I go with wonderboard 1/4" or 1/2"?<HR></BLOCKQUOTE>
Old 07-03-00, 03:07 PM
Guest
Post
Definitely use a 1/2" cement board and be sure to install it per the manufacturers recommendations
