size of tiles
Old 07-27-00, 09:38 AM
Guest
Post
Can 12 X 12 or 13 X 13 floor tiles be used as tile for a tub surround and countertop? If so, what could be used to finish the edges if there are no trim pieces available?
Old 07-27-00, 09:44 PM
Guest
Post
We have done several bathrooms using large tiles - and it turns out beautifully. Some manufacturers are beginning to make trim pieces for larger tiles, but they're hard to find and choices are limited. If you go with a regular tile, the edges can be finished with Schlueder strips - available in different styles at most tile stores. Another choice would be to go with a porcelain tile. Porcelain is the same all the way through, so when a piece is cut, no trim pieces are needed. Another consideration would be decorative trim pieces which come in a huge variety of shapes, colors, and designs. Good luck!
Old 07-31-00, 07:13 AM
Guest
Post
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Kelly:
Can 12 X 12 or 13 X 13 floor tiles be used as tile for a tub surround and countertop? If so, what could be used to finish the edges if there are no trim pieces available?<HR></BLOCKQUOTE>
This site can help you
www.askthetileman.com
