drilled holes in ceramic tile
After taking out the old vanity and side closet that were installed on top of the tile in the bathroom, there are rather big holes in some places (1/2 inch diameter); a couple on the floor and some on the walls. How do I fill these holes or do you replace the single tile effected?
Hi Amy;
You want to replace those tiles. (otherwise you will have ugly filled 1/2" holes in your tile)let us know what size the tiles are and how wide the grout joints are.
Then we can recommend the proper way to remove and replace them. Come back and post!
Good Luck
Rich Gately (Tileman1)
www.gatelytilecompany.homestead.com
Good Luck
They are the standard bathroom 1960 41/4 tile with 1/8 grout.
quote:<HR>Originally posted by tileman1:
Hi Amy;
Good Luck
www.gatelytilecompany.homestead.com <HR>
Hi Amy;
I am going to make this easy on myself rather than typing it all out again.
There is a post about halfway down the page Authored by Missy M called "One tile removal" there is a reply by Mr. John Bridge that tells exactly how to remove 4 1/4 Tile. Follow those directions exactly and go slow and you should have NO PROBLEMS!
Good luck and Regards
Rich Gately (tileman1)
Amy,
There is a guy in Dallas who, before he got into the tile business, was a painter. His name is Sonnie Layne, and he is a worse blabber mouth than I am. Send him an email, and he'll send you several paragraphs on how to paint your tiles. Tell him I sent you, and he'll send you a whole chapter.
slayne@ticnet.com
John Bridge
slayne@ticnet.com
John Bridge
quote:<HR>Originally posted by John Bridge:
Amy,
slayne@ticnet.com
John Bridge<HR>
Thanks for the info and I will let you know the outcome!
