installing porcelain tile
Old 12-08-09, 07:35 PM
R
Talking installing porcelain tile
I Am Installing18"x18"Porcelain(PEI4) An Exposed Patio Over 40+Year Old Concrete.My Questions Are1)Should I Acid Wash Before I Start My Prep?(What To Use To neutralize The Acid?)2).What Type Self leveling Patch To Use Outdoors(With Or Without An Additive?)3)What Type Thin set & Grout?( Preffer Not Using E Poxy )4)What Type Sealer If Any For Grout?.The Patio A butts The garage (That Is Cut Into A Hill & There Is Apx. 6' Of It's Wall Above The Patio & There Is Watter Leaking Down Into The garage Where They Meet.Would A Membrain Like WP6000 Or Red guard & Silicon Fix This Problem? I Would Be Thankful For Any & All Advice That You Can Give.
Roy
Last edited by stickshift; 12-08-09 at 08:04 PM. Reason: Removed last name and email address for privacy
Old 12-09-09, 02:27 PM
HotxxxxxxxOKC's Avatar
What is the condition of this slab?
If it's got lots of cracks, you shouldn't install any tile out there. If it's in decent shape, a good modified thinset like Flexbond or a Mapei product.
Just use a normal sanded grout founhd at HD or Lowes.
Use a quality sealer, like AquaMix or Impregnator 511.
Can you take a picture of this garage wall leak area?
