Bathroom subfloor questions
Hello,
Currently remodeling a our 2nd floor bathroom. Ripped up the vinyl flooring along with the 1/4" plywood. What I'm left with is 3/4" plywood with the floor truss' 24" O.C. The support span for the truss is about 4 or 5 feet. We plan on installing ceramic tile. My question is do I need another layer of plywood? Would just ditra be good enough? Thanks.
Mark,
Either add an underlayment grade plywood of min. 3/8" then Ditra or cement backer, or find someone that will sell you a small amount of Ditra XL. The thicker Ditra XL is rated for the 24" span with 3/4" ply in excellent condition.
Jaz
Jaz
Jaz
Jaz
I will be installing a tub also. Should the plywood go under the tub or install the tub first?
