Tile finishing question...
Old 02-21-10, 11:29 AM
I have just installed a tile floor and am ready to grout.
While cleaning the floor, my wife remarked how much better the tiles look when wet. They are a textured, ceramic imitation granite tile, with no sheen at all to them.
I see there are some sealers that provide a low or semi-gloss finish to the floor.
Can I use one of these products to seal the tiles before/after applying the grout? If applied before the grout, will this make the grout cleanup easier?
Would this treatment need to be re-applied at certain intervals - yearly?
Is there one product better than others? Any to avoid?
All input most appreciated!
Old 02-21-10, 11:59 AM
Tom,
it's important to know whether those tiles are ceramic or porcelain.
From your description I've decided you have porcelain tiles, either matte glaze or through-body unglazed. Not sure, can't tell from here.
If they are glazed, you've got what you bought. If unglazed, you can apply a topical dressing to give them any level of sheen you want. Of course that means more maintenance since this dressing is essentially a type of wax.
Jaz
Old 02-21-10, 12:11 PM
Thanks.
I just checked the fine print on the box -should have done it first.
They are glazed porcelain. Must be matte glaze. Surprise for me...
So -no dressings.
Anything else I should be aware of - differences between ceramic and porcelain?
Old 02-21-10, 05:21 PM
Porcelain IS ceramic, just harder-stronger. The only real difference when installing them is to make sure you're using a modified thin set if setting over cement backer or wood underlayment. (wood not recommended however). But you're finished now....so....
And now a break, I'm getting ready for the USA hockey team's victory over Canada. Hopefully! Beer 4U2
Jaz
Old 02-21-10, 08:05 PM
Well...
did you have money on the game?
Miller was awesome.
ps -I did use the modified thinset over cementboard, so I guess I'm all right.
