How to fix etched marble
Old 05-05-10, 12:58 PM
I destroyed a couple marble tiles by dropping vinegar on the floor which wasn't cleaned for at least a couple hours. Now these tiles look like they are dull. I feel so bad about it.
Is there an easy fix to get the shine back? Please help. I do not want/can not afford to have the entire flooring redone.
Thanks.
Old 05-05-10, 03:13 PM
HotxxxxxxxOKC's Avatar
What is done is done. Only way is to get them back to normal is to grind/hone them down. If it's not too many tiles, then it shouldn't be that expensive. Also, you should have some spare tile? If so, remove those bad tiles and replace....
