mortar the tile, the floor, or both?
Old 07-09-10, 09:44 AM
which way is best? and how do i remove excess mortar in the tile joints?
Old 07-09-10, 10:08 AM
Received 57 Votes on 54 Posts
Generally you put in on the floor only with a notched trowel
Whatever tool fits in the gap between the tiles can be used to remove mortar in the joint space - pencil, scrap of wood,...
Old 07-09-10, 11:14 AM
great thanks alot.
the message above was too short so i am typing this to make it longer
Old 07-09-10, 11:22 AM
Gunguy45's Avatar
Super Moderator
Received 2 Votes on 2 Posts
I've also heard that it helps to put the tile tight to the ones already down, press and slide over to get the right gap. That prevents thinset from bulging up between tiles.
With a little practice...it's gotta be easier than going back and cleaning the joints.....
