bullnose on vertical edge, cement board edge?
Old 08-20-10, 07:43 PM
I'm tiling a wall up to an outside corner. I want to end with bullnose along the vertical edge. Do I cutback my cement board (Hardibacker) at the edge to allow the bull nose to wrap around?
The other side of the edge will be sheetrock & paint.
I think I need the Hardibacker to end about a half inch before the edge.
Old 08-21-10, 05:24 AM
Received 4 Votes on 4 Posts
Bullnose has one curved finished side and a flat back. I'm not sure what you are talking about when you say wrap around. Do you have bullnose, or mud caps or something else?
Old 08-21-10, 08:09 PM
Sorry, not bullnose, but probably quarter round strips.
I have a vertical edge corner on a wall, tile on one side, sheetrock on the other. I was thinking of having a rounded edge transition. I could also use the long edge strips (plastic or metal), but I don't think it will look as good. I think my real question was about how close to bring the Hardibacker to a vertical wall edge, and maybe that depends on what tile or edge product I'm using at the edge.
Old 08-22-10, 05:10 AM
The cement board should go all the way to the edge of the sheetrock. Does your tile not come with bullnose?
Old 08-22-10, 01:32 PM
Yes, I can use bullnose at the edge. But I was thinking of using something with a larger radius, and wrap around the corner a little. Thanks for the advice to take the cement board all the way to the edge.
Old 08-22-10, 01:52 PM
Received 166 Votes on 147 Posts
I'm not a tile guy and I'm not sure of the correct terminology but I think there is a communication error. There are 2 types of bullnose [if that's the right term] one curves and stops on a flat surface [where the cement board and drywall are level] and another bullnose that has a 1/2" lip the covers the edge when the cement board is a 1/2" higher than the painted wall.
Hope I got that spit out well enough to make sense
Old 08-22-10, 02:36 PM
Yeah, I was planning to use the second type, with the larger turn radius. And my original question was if I should take the Hardibacker to the edge or not.
Old 08-23-10, 05:31 AM
Mark if you are talking about this, its called "mud cap".
American Olean Tile: Alysse 2" x 6" - Cafe Mud Cap
Old 08-23-10, 06:42 AM
Ya, that's what I was referring too
I've painted up against miles of tile but never installed any except on my own home
