What is gypsum cement, concrete, mortar??
Old 09-28-10, 03:52 PM
Received 16 Votes on 11 Posts
The shower pan I'm installing says to lay it in a bed of gypsum cement. What the heck is gypsum cement? I can't find it anywhere!
Old 09-28-10, 04:04 PM
W
Received 1 Vote on 1 Post
You're just not looking in the right places. Fairly common stuff. I use mason's mortar but I'm not a bathroom pro.
Gypsum cement
Old 09-28-10, 06:58 PM
Yeah, I came across that website, but was a little thrown off since it seems to be for sculpturing. Aparently I can use it for setting a shower pan as well I'll look at HD to see if they have it (doubt it). Otherwise, I guess I'll be using thinset (modified so it sticks to the plastic shower pan, right??). Also says panel/floor adhesive would work as well.
Old 09-29-10, 08:30 AM
W
I don't think you should use thinset. IIRC one of the tile pros here recommended not using it to bed a tub because it shrinks when it cures. I suggest using mason's mortar instead.
Old 09-29-10, 07:29 PM
That's what I'll be doing at this point. Sand/cement mix, just like the bathtub. Thanks.
