Tile to Cement Slab Transition Pieces
Anyone have a solution for a 24" square porcelin floor tile to cement garage slab transition strip? Longer and wider and stronger - the better!
ADA compliant a bonus. Thank you.
Welcome to the forums! Give us the difference in the tile versus the garage slab. How much of a jump do you have? Have you already installed the tile?
Larry
"Half of communications is listening, and you can't listen with your mouth."
Larry
Hey, I like the Reno Ramp and will try and find it. The tile is 3/8" thick. It is not installed. I have since found a vinyl transition piece that comes in a roll---hmmm, an occasional auto might run over it. Thinking the metal is best bet. Thank you Chandler & HotinOKC!
