Marble floor tile over concrete slab
Old 06-30-11, 07:29 AM
C
I'm about to lay white marble floor tile over a concrete slab. The slab was poured 50 years ago over a plastic moisture membrane. It has no cracks or other evidence of movement. Is DITRA or some other membrane necessary?
Old 06-30-11, 11:08 AM
E
I am guessing your slab is on grade, and if you are not in a cold climate all should be fine just setting it down as is. If it was a basement area with cold winters then options around floor insulation, subflooring and Ditra might be considered.
Old 06-30-11, 12:26 PM
C
You are correct. The slab is on grade, and our climate is quite warm most of the year. Thanks for your advice.
Old 06-30-11, 01:44 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Chris, good luck with the marble....will you learn to hate it, probably. It will be a bear to keep clean. Foot traffic and body oils will leave a track from the door to the most used part of the floor area. Fore warned is fore armed.
Old 07-01-11, 10:20 AM
Received 94 Votes on 83 Posts
I'm with Chandler - I've lived with marble floors and will never again (I won't use any natural stone on a floor, actually)
