Re-honing travertine
Old 08-08-11, 11:17 AM
Hey folks,
I have travertine floors throughout the downstairs of my house (appx 2k sq ft) that is looking a little shabby. I found this article on re-honing it and it seems simple enough. I just have a couple of questions that, hopefully, y'all can answer.
1) The article mentions that a 'floor machine' is required. I have one of these - will that work, or do I need something burlier?
2) Recommended products to use?
* For the 'Tile Sealer', I have the Dupont product that they sell at Lowes. Is there something better?
* Any recommended products for the sanding/grinding discs? How about sources for the products?
I think that's it for immediate questions, but I'm sure I'll come up with more. Thanks in advance for any input you can provide!
Old 08-08-11, 12:06 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Every time I've seen that kind of work being done...they use a much larger slow speed buffer/polisher. You could probably rent one...but they take a certain amount of practice and skill to use w/o getting swirl lines, gouges, and such.
Buying the pads and renting could run several hundred dollars. You probably don't really need a re-hone...but just a polish. Rehoning is something you normally see done in commercial buildings after lots of foot traffic.
JMO...not a flooring specialist....I've just seen it done.
Old 08-10-11, 03:13 PM
I can certainly handle that since, at least to my amateur ears/eyes, polishing sounds like less work than re-honing. Thank you!
I do wish the floor experts would chime in, though. Apparently I'm scary, or something, as they never seem to respond to my threads. *sniff*
My floor scrubber came with some lambswool buffing pads. Do you think a pass or three with those might brighten up the floor a bit? Is there a buffing compound of some sort that should be used?
I slapped a polishing disc on my random orbital and experimented with a dry pad on a piece of tile that needs to be replaced, and it seemed to help a bit, but... I don't want to do anything to ruin the floor!
