Tile look semi-laminate flooring repair
Old 09-12-11, 02:22 AM
T
Question Tile look semi-laminate flooring repair
I bought a house with fake tile flooring. It looks like a laminate but it's very unique, no repeating textures or colors. Also there are no seams.
I recently had some work done on a bathroom and part of it chipped away. It was very thin but very hard. The material reminded me of commercial vinyl tile squares (breaks if bent). I took some of it to home depot but they did not recognize the type of flooring it was.
I'd replace with real ceramic tile or a laminate but that means replacing the rest of the flooring in the house to match (2 other bathrooms, kitchen and laundry room!). Since I'm hoping to move, I'd hate to put the expense in, but I do need to prep the home for sale.
The closest laminate I've found is this: Laminate Wood Flooring from Fausfloor
Keep in mind, my floor does not look quite this nice or this uniform but the fake tile shapes are similar.
Does anyone know what type of flooring I have? I'd like to get it repaired without too much of a hassle.
I've included a picture:
Old 09-12-11, 04:44 AM
chandler's Avatar
Received 6 Votes on 6 Posts
This looks like a higher quality of linoleum, or roll flooring. You say there are no seams, so it can't be a product like Allure.
Where is the damage? Is it inside the bathroom? Why would you have to replace it all if you only needed to do one room?
Old 09-13-11, 03:29 AM
T
As I look closer at the flooring, it's pretty clear the floors are custom made in this home since the faux grout lines end with rounded edges at the edge of the room.
The damage is in the upstairs bath near the tub. The rooms look nice currently with matching faux tile, having one room different from the rest seems like a botch job.
Old 09-13-11, 04:55 AM
chandler's Avatar
Why would redoing one room look "botched". It is done every day. You can change the tone of a room by adding a darker or lighter tile, or by changing the design to a smaller or larger more consistent sized tile. Definitely consider laying ceramic tile in the bathroom. It will take the punishment much better than most other products.
Old 09-14-11, 05:20 AM
T
Thank you for the advice. I'm not doing that at this time. Does anyone else know what kind of flooring is installed in my home?
Old 09-29-11, 06:14 AM
T
After looking at a broken piece of the floor, it looks like it's a polished plaster substance
These are the closest I could find:
Plaster Styles | DJJ Italian Marble Plastering
Marmorino Carrara - Polished Plaster Finishes - Polished Plaster, Marmorino & Venetian Plaster Stucco Specialists UK
Specialized Concrete Overlay Systems | Pinnacle Flooring | Concrete Overlay Systems and Suppliers
It might be a thick layer of Venetian plaster or a stucco floor. The areas to repair are so small. I'd hate to re-tile everything if only 1-2inches of flooring are damaged.
