Cleaning grout
Old 11-24-11, 05:19 PM
Cleaning grout
What is the best approach to clean grout? What type brush should I use, and what type of cleaner should I use that I can find at Home Depot or Lowes?
TIA
Old 11-24-11, 08:09 PM
pist-n-broke's Avatar
TIA
Hello,
I have used a common general "spray" bathroom cleaner called Bam. I also used a tooth brush
to brush it into the grout , then water to rinse. A bit of a slow process... but... it seemed to work fairly well. I also re-sealed the grout after it was cleaned... looks good!
Hope this helps!
