removing old tile
Old 01-12-01, 06:43 PM
i am in the process of remodeling my bathroom. i presently have horrid tile around the tub and would like to replace it. how do i remove the old tile without ruining the cement backerboard?
Old 01-13-01, 11:57 AM
Unhappy
Hi tgildon,
I do feel sad because removal of properly installed tile on cement backer is virtually impossible to remove without destroying the board. You could remove it all and start from scratch ( this is what I would recommend) or if the job is solid you may be able to go tile over tile (on vertical surfaces this can be a little tricky to do!)
Good Luck
P.S. The cost of new backer board is a small price to pay for the advantage to check for water damage and to install the new tile properly to insure there will be none in the future. come back when you are ready to install the new board and we will explain how!
Regards,
Rich Gately (Tileman1)
http://www.gatelytilecompany.homestead.com
Old 01-13-01, 01:46 PM
I'm wondering if the old tile might be installed on something other than backer board? Mud, maybe?
