Go Back  DoItYourself.com Community Forums > Interior Flooring, Floor Coverings and Coatings Center > Wall and Flooring Indoor Tiling
Reload this Page >
Product to remove masonite type padding glued to concrete floor???
Old 01-16-12, 03:47 AM
We have just removed a wood floor from an apartment in Manhattan. We are left with a Masonite type padding/sound proofing which is glued with a black glue to the concrete floor with which we need to remove and we were wondering if there is a product that you are familiar with that could be applied to remove these surfaces.
Our intention is to install a marble tile product in place of the removed wood flooring.
Any ideas would be greatly appreciated.
Old 01-16-12, 03:56 AM
chandler's Avatar
Received 2 Votes on 2 Posts
Welcome to the forums! Would it be possible for you to post a couple of pictures (not close ups) of the "padding". I am unfamiliar with anything masonite would have used for such a purpose, and it may help us to give you a better answer. http://www.doityourself.com/forum/el...your-post.html
Old 01-16-12, 06:31 AM
sam floor's Avatar
Received 7 Votes on 4 Posts
Shouldn't be Masonite. It is sold in 4x8 sheets, similar to plywood.
Old 01-16-12, 07:35 AM
Received 46 Votes on 43 Posts
If you want to put down tile, I'd try only to use hot water and a scraper to remove the stuff.
Old 01-16-12, 01:21 PM
Is it possible that what you have is a Homosote panel. I do not know about New York but I have seen Homosote used to pad/insulate under floors in this part of the country. Is the material hard or does it dent easily like a wood fiber board or perlite board?
Old 01-16-12, 01:24 PM
sam floor's Avatar
You need to know for sure if your floor is concrete or haydite, before you try to install tile. Many apts have haydite floors.
