Backer Board Procedure
I just tiled my bathroom with backer board under it, with thinset. I used backer board screws every 6 inches throughout.
I am about to tile my 11x17 kitchen, and it has been suggested to me that I just need to run roofing nails into the joists.
If I can avoid putting down 400 screws, I will. What's the correct method? The floor in the kitchen is currently plywood and vinyl.
Thanks!
Thanks!
Galvanized roofing nails are an acceptable fastener for securing Hardibacker. Minimum length is 1 1/4".
If you are using Hardibacker, there are fastener detents on the face. Otherwise along the edge and every 6" in the field. Roofing nails are accepted, but I get a warm and fuzzy with backer screws.
Jaz
