Subfloor thickness requirement for porcelin floor tile
I need a pro's opinion on this 1 1/4 inch minimum thickness under floor tile.
My application is new construction.I have 3/4 inch tung and grove AVANTECH subfloor, screwed and glued to 12inch Engineered I joist(n80), 16 inches on center,with an unsupported span of 9 ft.
I have radiant heat under the avantech.The finished space is an entry hallway that extends 32 ft. with laundry room and bathroom on one end.
I will be installing Engineered hardwood flooring on adjacent floors and want to minimize the hight diference to the tile floor.
If I use 1/4 inch hardee board with my 5/16 tile, my hight delta is 1/16.
If I use 1/2 dura rock , instead of the 1/4 hardee board ,my delta is 5/16, or the thickness of my tile.
Will I have a problem if I shave the minimum by 1/4 inch?
I have both in my house installed over 3/4" Advantech with a 19.2 truss spacing and have had no trouble with either. The 1/4" Hardee is in our entry foyer which gets less use than the 1/2" Dura Rock floor in our master bath but both are crack free after 10 years.
First things first. Is the tile you are installing ceramic tile or natural stone?
Cement board adds no structural strength to the floor. It only serves as a good bonding surface for thinset and tile. Using 1/4" or 1/2" hardi will not make a difference.
In general, the 1 1/4" rule you mention is for 2 layers of plywood when bonding the tile directly to the plywood (not the best method). If you are using natural stone, you also need 2 layers of plywood, but not so for ceramic/porcelain tile. If you are using natural stone, its also likely that your joist system is not adequate.
So, if you are installing ceramic/porcelain tile. The 3/4" advantec and 1/4" hardi is ok. You could also look at sheet membranes like "Schluter Ditra" instead of the hardi. Its only 1/8" thick and will do a better job than the hardi will.
