Will a sub floor work?
Old 07-27-12, 06:55 AM
My basement bathroom is concrete. In a few areas where the pipes are running there is some rough areas where the concrete is not smooth. If I use a sub floor, do I need to repair the concrete areas that are uneven?
See pictures,
Thanks!
Old 07-27-12, 08:51 AM
Received 94 Votes on 83 Posts
What flooring do you intend to put down in this room?
Old 07-27-12, 09:35 AM
I have not really committed to any type of flooring yet, leaving my options open.
Old 07-27-12, 10:12 AM
Personally, I'd be leaning toward ceramic, which would probably not require any work to the concrete.
Old 07-27-12, 02:45 PM
chandler's Avatar
Received 5 Votes on 5 Posts
Wood and concrete in direct contact are not friends. If need be, I would float the irregular areas with Self Leveling Compound. I, too, would lean toward ceramic tile as opposed to carpet or wood.
Old 07-29-12, 07:41 PM
Bathrooms need ceramic tiles which go directly on the concrete. Of course you'll need to make the concrete flat first.
Jaz
Old 07-30-12, 09:10 AM
Thanks everyone for the advice. I will level and use ceramic tile!
