Removing Vinyl Tile squares from a concrete floor?
Old 10-17-12, 06:49 AM
Any ideas on how you would remove 12 inch Vinyl Tiles from a concrete floor? Thanks!
Old 10-17-12, 07:21 AM
Received 94 Votes on 83 Posts
Hot water, a scraper and a lot of elbow grease.
Since I know from your other post you intend to put ceramic on the concrete, I can tell you a solvent for the adhesive is not advised in your case.
Old 10-17-12, 10:00 AM
Thank you for your reply! Appreciate it!
Old 10-17-12, 10:27 AM
sam floor's Avatar
Received 15 Votes on 11 Posts
If they are peel and stick, a heat gun or hair dryer will help make the glue release the tiles.
