Tile Cutting Problem
I have 12 inch ceramic tiles and I can't cut them straight. I am using a 15 inch double pole tile cutter. The tile cuts straight for about 4 inches and then breaks off in the middle. How do I cut a 12 inch tile straight every time?
Don't know what type of tiles you have, but there are some that simply won't cut on a cutter. You may need a wet saw.
John
http://www.johnbridge.com
John
