How to fasten this a tile floor?
Old 02-27-13, 08:06 AM
Question How to fasten this a tile floor?
Amazon.com: Security Door Brace / Door Brace. Stops Home Invasions & Burglars. The OnGARD Door Brace Withstands up to 1775 Lbs of Violent Force. Not a Nightlock Nitelock: Everything Else
The homepage of OnGARD says it comes with woodscrews for fastening to a wood floor. But if installing in tile have a contract professional install it.
Is there a way for a non pro homeownder like me to do the job?
The tile in entryway in front of front door is a polished glaze ceramic tile.
Thanks!
I
Old 02-27-13, 10:21 AM
Received 153 Votes on 136 Posts
They make special drill bits for drilling thru tile. I would think if you drilled thru the tile and then used a long enough wood screw to secure it thru the subfloor - that should work.
Wait and see what some of the others have to say
Old 02-27-13, 10:54 AM
The subfloor is concrete.
Hope somebody has ideas
Old 02-27-13, 11:02 AM
Tap cons work in concrete but I don't know if they would work with your bracket/latch.
Old 02-27-13, 11:07 AM
Gunguy45's Avatar
Super Moderator
Received 2 Votes on 2 Posts
I would look at another option like the Strikemaster. Drilling in the tile and into the concrete below may not provide the strength needed.
