Glass backspalsh - trowel and spacer size
Old 03-16-14, 07:48 AM
I am installing 3x9 white glass tiles for a backsplash. The area is about 54"x54". I am trying to figure out what size spacers and trowel to use.
I've read that glossy tiles look bad with big grout lines. Should I use 1/8" or even 1/16" spacers?
Should I use a 1/4" trowel?
I would actually prefer to have no grout line, but am worried the tiles are not uniform in shape and that might look odd.
Old 03-16-14, 09:15 AM
Received 94 Votes on 83 Posts
Can you see through the tiles at all? If so, you don't use a notched trowel as the lines can show through the tiles.
I would lay a few tiles out on a table or something and see how they look butted up to each other - if they're not uniform enough, you could experiment to find the smallest grout line that accommodates the irregularity.
Old 03-20-14, 08:49 AM
You can't see through them. There is a white backer "paper".
