replacing shower tiles
Old 07-23-14, 10:29 AM
G
My shower tiles were "covered" with a paint by the previous home owner and starting to peel off, I want to replace the bottom-floor tiles.
It is a basic thin tile (about 4x4") and am wondering if I gently remove the tiles, can I just use the same sub-base? There does not seem to be a leak issue.
thanks,
Old 07-23-14, 02:39 PM
czizzi's Avatar
Received 14 Votes on 12 Posts
How old is the house? What type of plumbing is present? Is the tile set in a mud bed or on cement board? If it was installed correctly, the tiles will not come off without a fight.
Old 07-23-14, 02:44 PM
G
I should have given more information, house is only about 10 years old, I assume cement board is under the tile but we moved to this home recently so I am not sure. I was going to chiesel away each tile ...
thanks for the reply.
Old 07-23-14, 03:09 PM
czizzi's Avatar
Do you have access through a panel behind the shower faucet wall that may be located in a closet? Or, take the trim off the shower handle and see what is under the tile.
is there a mud cap or bull nose where the tile meets the wall?
