creating a shower pan out of tile
Old 03-14-01, 11:17 AM
Hello - we just bought a 30 year old house in southern California. The last owners botched a shower leak repair and we've had to tear the whole thing out - including the shower pan. Since the pan was an awkward size (54x34) and has to be special ordered, we thought we'd bypass the process by simply continuing the new wall tile down across the floor. We were going to add a bench on one end (frame made out of wood and then tiled over) and use a 4x4 as a threshold. The base floor is cement and is directly over the foundation. Can we just lay the tile down? What do we need to prep the area?
thanks in advance...
Old 03-14-01, 04:04 PM
Oh, Agatha, you've got your work cut out for you. This is one of the things we talk about often on this board and others. The best place to start is an article written by my friend Michael Byrne.
http://www.jlconline.com/jlc/archive...ers/index.html
Then go to my site and read about shower pans and what they do.
http://www.johnbridge.com/shower_pan_replacement.htm
Then, if you are still up to it, come back with more questions and we'll help you.
John
Old 03-14-01, 05:50 PM
Wow. I knew it sounded too easy. Thanks for the references - they're exactly what we needed. I'll let you know how it goes!
