Identify old flooring
Old 11-08-14, 07:57 PM
Size:  42.8 KBName:  IMG_20141108_215324.jpg
In the process of redoing a bathroom this old flooring was found under the sheet laminate. It appears to be some type of tile but there are no seams and its all smooth. Its about 1/4" thick. House was built in the 50's. Has anybody seen this before? I'm curious as to whether or not it could contain asbestos, as I'm thinking of removing it.
Thanks.
Old 11-08-14, 09:06 PM
Received 25 Votes on 19 Posts
Could be linoleum, might have asbestos but I kind of doubt it.
Linoleum - Wikipedia, the free encyclopedia
Old 11-09-14, 04:08 AM
Received 120 Votes on 107 Posts
Is the floor structure wood or concrete? It looks similar to terrazzo which is a really durable finish that is applied over the concrete.
Old 11-09-14, 06:43 AM
Floor structure is wood, otherwise I thought about terazzo as well.
I'm kind of leaning towards really old linoleum. In tearing up a small corner it looks like it has some type of tar like paper backing, as there's black residue on the wood...
Old 11-09-14, 07:08 AM
sam floor's Avatar
Received 7 Votes on 4 Posts
Could very easily contain asbestos. Only way to be sure is to have it tested.
Old 11-09-14, 11:39 AM
No way is that terrazzo. That's linoleum. It's probably 6' wide and about ⅛" thick. It might have been installed over tarpaper using linoleum paste.
I doubt it contain asbestos, but no way to know without testing the lino, paste and backing. Even if it does contain asbestos, it can be removed without creating a health hazard.
Jaz
Old 11-11-14, 03:53 PM
Now you've done it! Once a material is suspected of containing asbestos it DOES contain asbestos UNTIL proven otherwise. Only way to prove it is NOT asbestos is by laboratory analysis.
Unless a material is one known to often contain asbestos I refrain from even mentioning the A word.
Old 11-11-14, 04:18 PM
sam floor's Avatar
Just take it up safely and you don't have to worry about what's in it. And a DIYer can take it up.
