Need Help 2 subfloor issue
Old 07-13-15, 11:22 AM
N
I just bought this house.....I am upgrading the mudroom that connects the garage to the house When I peeled back all the carpet 1/2 my subfloor was cement, the other half plywood. ugh
Ok now I want to do ceramic tile in the mudroom but I have a few problems. If I add Hardie board or Wonderboard to the plywood side then that side will be higher then the slab side. I thought about ripping out Plywood, but it goes underneath all the wall framing and that seem to be way too much work. I know everyone says not to put Hardie Board on top of cement.....but I need to find a way to level floor and strengthen the plywood side so the thinset/mortar doesn't crack. Any ideas
Old 07-13-15, 11:28 AM
Received 94 Votes on 83 Posts
Welcome to the forums.
Let's start at the basics - what's the composition of the plywood floor plus the size, spacing and unsupported span of the floor joists?
Old 07-13-15, 11:50 AM
N
Sorry 3/4 Ply 16" on center
no moisture issues, nothing on Plywood or concrete
The entire plywood part is about measure 8'2" from slab to wall and 5'6" wide
The portion with slab is about half as large
Old 07-13-15, 11:59 AM
What size are the joists? Which of the two measurements you provided is their span or is it something else?
Old 07-13-15, 12:01 PM
N
Joist are 2 x 4
span is 5"6"
Old 07-13-15, 12:05 PM
N
Sorry 2 x 6 joist not 2 x 4
Old 07-13-15, 12:36 PM
czizzi's Avatar
Received 14 Votes on 12 Posts
Which is toward the house, and which is toward the garage? The easiest to raise the concrete is with self leveling compound. You roll on a self leveling primer, let it set up (2 hrs) and then pour on the self leveling compound. It comes in a powder and you mix it with water. Pour it on and then help push it into place. It sets up relatively quickly, so work efficiently.
Old 07-13-15, 12:42 PM
N
the door leads to garage if I used self leveling compound I would have to pour it 1/4 deep is that even possible?? I thought the compound was just for filling in dips in the floor not covering the entire floor
Old 07-13-15, 01:02 PM
czizzi's Avatar
Depending on the brand, you can make single pours with SLC thicker than that. Maximum thickness will be called out on the label, and again, it varies by brand. Level the floor to the plywood and then you can run ditra over the whole floor to tie them both together as one.
Old 07-13-15, 02:44 PM
We never learned if the floor's perfectly even at the junction. Might be able to avoid a step if it's the same and otherwise in good shape.
Jaz
