Anyone use Simplemat for tiling countertop over washer/dryer
Old 08-22-15, 08:06 AM
I'm looking at tiling the top counter of an enclosure built over the washer/dryer. Has anyone used Simplemat? Any pros/cons for using it over the laundry machines?
Old 08-22-15, 10:38 AM
chandler's Avatar
Received 2 Votes on 2 Posts
Simple mat is good. It is unforgiving in that you must place your tile correctly the first time as there are no points for second place. I am not sure how it lasts with moisture on a horizontal surface, but your application seems to be free of water. It is mostly used for vertical surfaces such as splash backs but should work fine for your application. How do you plan on covering the edge of the tile and mat?
Old 08-24-15, 06:10 PM
planning on using bull nose tile for the edge. Thanks!
