hardwood under wall to wall
Old 10-14-15, 12:03 PM
Just removed carpeting from two rooms and found beautiful hardwood underneath. The problem is now I have the tack strip and staple holes from the carpet. Can that be repaired, and how do you do that?
Thanks
John
Old 10-14-15, 12:54 PM
You can see it and we can't. Pull up all the tack strip and staples and see how it looks - might be worth refinishing, might not.
Old 10-14-15, 02:33 PM
If the only damage is from the tack strip - it can be filled and sanded. Anything minor is easy to hide with filler.
Old 10-14-15, 04:40 PM
Any form of filler is going to show, even the so called "stainable fillers".
Been there done that way to many times trying to show customers.
Old 10-14-15, 06:56 PM
Handyone's Avatar
http://www.doityourself.com/forum/el...-pictures.html
See above for how to insert pictures.
For me, I would leave it alone until you decide if you want to invest in refinishing. The Paste filler used in refinishing will hide most of the nail holes/bleeding and fill gaps between planks.
The nails holes will always be visible, but just adds character.
If you have a typical White or Red Oak Plank floor from the 50's or earlier, you will not believe how beautiful this can look when refinished.
