Cutting 13" Floor Tiles
Old 04-07-01, 04:50 AM
Guest
Cool
The floor tiles I have are 13" square and trying to cut them because of their size means we are breaking too many. Can you suggest any tips or tools to help. The tiles are exceptionally hard.
Old 04-07-01, 04:59 AM
some help
hello
A tile saw is the only way to go...take it slow so the saw can cut without working and you should not break many...go real slow as you get to the end of the tile...Good Luck..
Old 04-07-01, 02:12 PM
Guest
If you have a good tile cutter, you shouldn't have any problems. If you are trying to cut a small piece off, then score it and break off the piece with some tile nippers. If you need a 1 inch piece, then cut a 2 inch piece first, and then cut it in half..it's always easier to cut any size piece in half.
Old 04-08-01, 02:31 PM
I have run into some tiles that won't cut on a tile cutter. If this is the case, the tiles need to be sawn.
John
http://www.johnbridge.com
Old 04-09-01, 05:36 AM
Guest
Hi All,
I agree with John there are some ceramics that are very hard to cut on a cutter and need to be sawn, especially many porcelain goods.
Regards,
Rich Gately (Tileman1)
http://www.gatelytile.com
Old 04-09-01, 07:54 AM
EDDorsey
Tile cutting
Home Depot will cut tiles for you on a wet tile saw. Most stores have them, either in the tile area, or in the tool rental area. Pricing varies, as one store gave us two cuts free, then $1.00 per cut after that, yet they considered two cuts for a notch out of a tile to be one cut! At another store, our last three tiles we needed cut the guy just gave 'em to us, no charge.
Old 04-16-01, 01:17 PM
Guest
Thumbs up
I've had very good (though limited) luck with a masonry cutting blade in a circular saw that I didn't care much about. VERY dusty. Wear safety glasses. Other than that, I just clamped the tile in my Workmate, finished side up, and cut it like lumber. Much faster than the "tile cutting" jig saw blades. For complicated shapes I make lots of cuts to the line, then tap each sliver with a tile scrap to break them out, then go pack around with the circular saw blade across the broken edge to get a smooth line.
Old 04-25-01, 03:47 AM
Guest
Lightbulb
Use a Diamond Circular Saw blade. Which can be use in a Skilaw, Saw bench or drawsaw.
Depending on the saw, and that size of your job, they are in the range of $20-$500.
Russ
