Re-caulking a small section?
I caulked the gap between my tile and tub about 2 months ago. It looks great and is holding very solid, in part because it is right onto a refinished tub surface. I have one corner section that has a small bubble in the caulk and looks bad because it wasn’t tooled correctly. Can I replace just this section?
The section is about 6 inches long. I was thinking I would replace about a 3-4 foot section. My thought is to cut into the caulk under the tub spout down to the tub surface, then horizontally until I get a nice piece to grab onto and pull it out to the corner and around the corner to extend out another foot or two where I will also carefully cut. Then clean the tub surface really well and make sure it’s dry and go ahead and re-caulk. I really don’t want to re-caulk the entire tub and the caulk is so new that it is still bright white. I think the problem was that the caulk didn’t get enough time to cure and that area is where the most water collects. That is why I would plan to extend it out to about center tub.
I also have a curtain clip affixed to the tub and tile and would have to replace that if I wanted to re-caulk the entire tub. In addition the side gap between the tub and tile is about3/8” so that would be a lot of caulk to replace that otherwise looks brand new and is attached solidly. Thanks for the help!
