Cleaning grout haze
Old 08-16-16, 08:45 AM
Cleaning grout haze
Me again!
I have completed grouting my vinyl tile about 5 days ago. There is still a noticeable haze on the tile and I am wondering if there's a trick to removing it? The pre-mixed grout advised not to expose the grout to water for 7 days. I read online that Windex works. I tried wiping each tile but the haze is still there.
Does anyone know any tricks to getting grout haze off of vinyl tile?
Thanks!
Old 08-16-16, 08:56 AM
Received 3,986 Upvotes on 3,578 Posts
They don't want running water to hit the tile for seven days..
The haze usually gets removed several hours after grouting or at least by the next day.
There are different types of flooring tile grouts. Some require mineral spirits for cleanup.
What was listed on the package for haze removal or cleanup ?
Old 08-16-16, 09:06 AM
Okay, I will try that. There was a lot of conflicting information - I didn't want to ruin the grout. Hopefully it's not too late to get the haze off. Thanks!!
Old 08-16-16, 09:24 AM
Received 1,267 Upvotes on 1,207 Posts
Be careful with mineral spirits on vinyl tile, the vinyl could get damaged.
Old 08-16-16, 09:36 AM
The package just said to wipe haze a few hours after laying the grout. The same package also advised not to walk on the vinyl for 24hrs after grouting, and to also be careful with how much water you get into the grout via the sponge before it sets. Because of all the conflicting information I decided to leave it. It isn't horrible, but you can tell the haze is there. Do you no longer suggest vinegar? Am I too late?
Here's a product link to the tile: Shop Cryntel Italiastone 12-in x 12-in Groutable Slate Peel-and-Stick Stone Luxury Residential Vinyl Tile at Lowes.com
Here's a product link to the grout: https://www.lowes.ca/surface-prepara..._g1536850.html
Old 08-16-16, 09:46 AM
Shadeladie's Avatar
Super Moderator
Received 393 Upvotes on 321 Posts
Your second link to the grout, just takes you to the main page.
Old 08-16-16, 09:48 AM
Mineral spirits is not terribly strong. I'd try it on one tile to see if it removes the haze.
Use it sparingly.
I originally recommended 50-50 warm water and vinegar before I saw vinyl tile.
You could still try it. It's nowhere near as strong as mineral spirits.
Old 08-16-16, 10:18 AM
Not sure why the link isn't working, here it is again.
https://www.lowes.ca/1/1/223236-946m...skill-set.html
Just in case, it is the last one (purple package) on this page:
https://www.lowes.ca/1/3/premixed-grout
I will try the vinegar/water mix first and hope that doesn't damage the tile.
Old 08-16-16, 10:39 AM
Shadeladie's Avatar
Super Moderator
Not sure why, but both those links just take me to the main page too.
Old 08-16-16, 10:46 AM
Weird! I'm sorry. If you're really interested just google search 'Premixed vinyl tile grout Lowe's' and it's the purple tub product in the links that follow. No worries though if not.
