Basement floor unlevel
Old 11-04-16, 11:31 AM
N
I am in the process of finishing an unfinished area in my basement and have run into a wee bit of a problem. The floor in the basement is extremely unlevel. I first noticed this issue when I was framing my fish room but did not know the full extent until I realized there is at least a 3/4 - 1" gap or more between the frame and the floor joists near the middle of the room. I have head it is not uncommon for the floor to be unlevel but the area leads to the finished part of my basement and I want to put tile and a new french door to separate the two areas. Will this be a problem?
Thanks in advance
Old 11-05-16, 12:53 AM
Marq1's Avatar
Received 946 Votes on 859 Posts
That seems a little excessive but I would agree a basement floor will probably not be perfectly level.
A floor that is going to be covered (wood, tile) all have some requirements for levelness.
Typ this can be resolved by using leveling compounds which are poured onto the floor to fill the low spots.
Old 11-06-16, 04:25 AM
sam floor's Avatar
Received 25 Votes on 20 Posts
You are getting level and flat confused. For flooring, it is best if a floor is flat but does not matter if it is level.
