Anyone know what this strip is called?
Old 01-09-17, 06:58 AM
I need to replace mine since the original owner cut short of fully reach the other strip.
Thank you!
Old 01-09-17, 07:08 AM
Received 1 Vote on 1 Post
It's a tile transition strip. Here's a similar product that might work for you:
https://www.lowes.com/pd/M-D-Buildin...e-0ff893f2872a
Old 01-09-17, 08:51 AM
Thanks! Awesome, I'll take a look a our local hardware store.
By the way, do I slide it from one end to the other or can I just lightly tap it down from the top?
Old 01-09-17, 09:58 AM
Usually they push in from the top once you have installed the little mounting track. Hopefully you will be able to find a piece that will work with your existing track; that will make it easy to swap out the top.
Old 01-10-17, 07:28 AM
czizzi's Avatar
Received 9 Votes on 7 Posts
Is it made out of rubber? A flooring supply house (not box store) usually carries a wide variety of transition strips tha would match what you have. See if you can find a profile match here: Johnsonite > Wall Base, Finishes & Accessories > Finishing Accessories
Old 01-10-17, 07:57 AM
Awesome! Thank you. I'll check it out. And yes, it's made out of rubber.
