Cutting a hole in tile
Old 05-24-17, 05:03 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi All, shower head pipe will fall in the center of a tile, what would be the best way to drill a hole?
Geo
Old 05-24-17, 05:05 AM
Received 754 Upvotes on 659 Posts
With a tile drill bit. Go larger than you need so if your placement is slightly off it won't matter. The escutcheon plate will hide it.
Old 05-24-17, 05:08 AM
Norm201's Avatar
Received 674 Upvotes on 597 Posts
Get a glass or ceramic drill bit. Using a center punch tap slightly to provide a starter point for the drill. Use a bit of water to cool drill as you drill hole. You can buy a diamond edged hole saw for the same purpose.
http://www.dhgate.com/product/fs-hot...261660645.html
Old 05-24-17, 02:20 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I use this one, similar to the one Norm mentioned. It gives a reservoir to hold water while you drill to keep the heat down. QEP 1-3/8 in. Diamond Hole Saw with Water Delivering System-10569Q - The Home Depot
Old 05-24-17, 02:56 PM
Norm201's Avatar
Larry, nice. I did not know those were available.
Old 05-24-17, 03:16 PM
chandler's Avatar
The sticky pads stick to the tile and to the blue guide, which keeps the water in contact with the bit. It all peels off and you got a perfect hole with no burns.
Old 05-24-17, 03:54 PM
Marq1's Avatar
Received 1,140 Upvotes on 1,033 Posts
What kind of tile?
Ceramic, a carbide hole saw will zip right through, porcelain will cut but it's a little harder, a diamond hole saw will work great.
Either one is not terribly expensive assuming a one time inexpensive 1" size.
Old 05-24-17, 08:02 PM
czizzi's Avatar
Depends on what type of tile you have. Others have given options. But this goes further to the actual planning stages of the tile install. I always plan my tile so that all elements from diverter valve, to tub spout to hand held adapter so that everything falls on a grout line so there is no cutting in the middle of a tile.
Problem is with today's lust for large format tiles. Leaves little to work with as far as planning.
As an aside, I disagree with Norms suggestion to hit it with a center punch to start your pilot hole. Just asking for a cracked tile. I use a very small glass bit to start the hole and progressively get bigger. No chance of cracking a tile.
Old 05-24-17, 08:50 PM
Norm201's Avatar
if using a glass or ceramic drill bit, without a slight tap from a punch to get past the glaze, your drill will wander all over the place. I never had cracked tile from that procedure. A very slight tap is all it takes to assure a precise location to start the drill. I've used this procedure on new and existing tiled walls and never a failure.
Old 05-25-17, 04:46 AM
czizzi's Avatar
You will note that I said "glass bit" the smallest one I have I believe is 1/8" and is shaped like an arrow head. It does not wander when you start it, it bites immediately and begins to do its job. Would you also recommend hitting a piece of glass mosaic with a center punch? Tile, in and of itself, is pretty fragile until it is embedded in a layer of thinset.
I'm glad the procedure worked for your bathroom remodel, I just don't think it is a good recommendation to use a center punch for others who may be using a softer ceramic or like I said, glass tile.
Old 05-25-17, 08:57 AM
Marq1's Avatar
Just goes to show there is no single "right" answer to any question, what works for one may not work for the other.
Old 05-27-17, 04:21 AM
Geochurchi's Avatar
Chandler, look's like a nice setup,will look for one when the comes.
Geo
