Kitchen: minor floor fix up
Old 07-14-17, 05:43 PM
Hi. We want to remodel our kitchen next year. In the meantime I'd like a quick fix. We currently have ceramic tile. I was thinking of painting the grout white (it is now black/brown). The thought of painting the tile came across my mind, but I found contact paper that I like which is waterproof and can be used on walls and counters.
Is it a bad idea to use contact paper over each tile? I would cut them in 1'x1' squares (same size we have now) and apply to each tile. I am guessing I would need to seal it? Any thoughts on this?
Thank you!
Old 07-14-17, 07:31 PM
czizzi's Avatar
Received 9 Votes on 7 Posts
Contact paper? Really? On a floor? This may take the cake as one of the most ridiculous ideas to date. The life span of your idea would be about 48 hours before they would start peeling up.
Hold for your remodel and live with what you have until then.
Old 07-14-17, 08:28 PM
Lol- that bad huh? Oh boy. Believe it or not there are a ton of how tos online which is where I got the idea - although I was skeptical. I thought maybe a sealer would help? Would paint hold up if I went that route? The tile is not terrible but I'd like to brighten it up.
Old 07-14-17, 08:35 PM
sam floor's Avatar
Received 7 Votes on 4 Posts
How big is the kitchen? If small, you might get a year out of a loose-lay piece of vinyl rolled out over the tile without spending too much. Maybe.
Old 07-15-17, 03:40 AM
Received 120 Votes on 107 Posts
While painting the grout can work ok, painting the tile is not a good idea. Tub and tile paint doesn't have the best track record and applying it to a surface that will be walked on is asking it to fail sooner.
Old 07-15-17, 04:00 AM
czizzi's Avatar
They might have been talking peel and stick vinyl tile. But not sure if it would have much success over ceramic tile. The small format of your tile would cause many ridges and valleys where there would be no adhesion. You would need a flat surface to start with.
Old 07-15-17, 04:06 AM
Marq1's Avatar
Received 91 Votes on 82 Posts
Just wait! Just wait! Just wait!
Old 07-17-17, 08:22 AM
Received 46 Votes on 43 Posts
Just save your time and money and fix this when you remodel.
