Vapor proofing wood floor
Old 09-03-17, 07:00 AM
D
Good morning,im building a wood shed,when i laid the 3/4 inch treated plywood i failed to put a vapor barrier between the plywood and the joists/ground.is there a way i can insulate the floor/shed without causing condensation on the bottom of the plywood floor?i would like to heat/ac the shed.thanks
