How do I fix this gap between tiles?
Old 11-13-17, 06:18 PM
Can I just use caulk or do I need to grout it?
Old 11-13-17, 06:29 PM
Tolyn Ironhand's Avatar
Grout will likely give you better/easier results. You wouldn't even need any special tools. A plastic knife or even you finger and a sponge would be all you need for that small of a repair. Cost will be about the same.
Old 11-14-17, 06:01 AM
sam floor's Avatar
Grout is the right way between the tiles, but between the wood and tile on the other side, caulk is supposed to be used. I would just use caulk on both, much easier.
Old 11-14-17, 07:53 PM
Norm201's Avatar
Yes grout is the proper thing to use, but as Sam says , for this particular case just use caulk.
