Bathroom Remodeling - Tiling
Old 01-12-18, 09:23 PM
I
Hi Good Evening, finally I found a good place to get my answers
I initiated to remodel my bathroom (started with powder room). Powder room sub-floor (3/4 inch) is plywood and Underlayment(1/2 inch) was also ply wood. While removing tiles and adhesive, undelament got damaged. So, I decided to replace undelayment and successfully removed it.
Now, I am in a confused state on which approach to follow for undlayment,
Approach 1: Go with 1/2 inch plywood
Approach 2: 1/4 in plywood and on top 1/4 backer board.
I seriously want to go with baker-board approch, but since thin-set is suggested to use, I don't want to use bakerboard(1/2 inch) directly on sub-foor, since it will hard to replace again(if required to replace tiles) and I don't want to damage sub-floor.
Please provide ur suggestions for my clarifications:
  • Does my approach 2 make sense and good to go.
  • What type of thin-set to be used for bakerboard?
  • For Approach 1, can I directly apply thin-set on plywood for tiles or do I need to use any adhesive before applying thin-set?
Old 01-13-18, 06:45 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
If the 3/4 plywood is solid you can use 1/4 or 1/2 cement board,. The 1/4 plywood is not going to do anything for you.
Do not use adhesives (mastic) or pre mixed mortar, a good latex fortified mortar will do fine!
Old 01-13-18, 08:47 AM
I
Thanks for your response Marq1. I am not confident on my wood subfloor. I see moisture around toilet (there were some leaks when I took over), but within limits. I verified using moisture meter (
Old 01-13-18, 09:11 AM
XSleeper's Avatar
Received 1,845 Upvotes on 1,660 Posts
Usually a minimum of 1/2" ply is recommended over the 3/4, (screwed to plywood not to joists) then 1/4" cement board set in thinset.
Old 01-13-18, 10:07 AM
I
I was initially planning for 1/2inch plywood over sub-floor and then 1/4inch cement board. but the floor height is getting elevated 1/4 over main floor
If I decide to tile (porcelain tile) on top of 1/2 inch plywood, do I need to apply any adhesive before applying thin-set? or just thin-set is fine
Old 01-13-18, 10:31 AM
czizzi's Avatar
Usually the optimal mix is as follows.
1/2" ply + 3/4" ply (or vice versa) + thinset + 1/4" Cement Backer + thinset + tile
Use a marble threshold at the door to account for height changes. You need a beefy substructure for tile that is not in anyway beholden to the floor height in another room.
1/4" ply will do nothing for your mix and may create more issues down the road.
Old 01-13-18, 06:22 PM
I
Thanks for inputs. Instead 1/4" Cement Backer , I am thinking of Ditra to compensate height issue. Would this be a better solutions?
Ditra on 1/2 Underlayment plywood
3/4" wood (sub-floor) + 1/2" ply (underlayment) + thinset + ditra + thinset + tile
Old 01-13-18, 08:15 PM
czizzi's Avatar
Ditra might save you 1/8" at multiple times the price. Tiled quite a few floors with the mix I stated and never had an issue with height. It is only an issue in your mind.
Old 01-13-18, 08:32 PM
I
Gotcha thanks for ur inputs
