Proper shower tile backing in NYC apartment?
Old 05-11-18, 03:34 PM
A
Considering having a local handyman/Super that we've used for several jobs to do our bathroom. While he's done excellent work for us and does renovations on a regular basis in the rental building he manages, shower work requires a specific skill set. Trying to gauge whether he's going to work to code or pretty close.
Am I correct that the proper shower tile job would be a plastic membrane to studs, then cement board, then tile?
Anything specific I can ask him to ensure he knows what he's doing?
Old 05-11-18, 07:28 PM
Received 83 Votes on 78 Posts
Nope, tile board and grout are not waterproof.
Install tile board then a water proofer like Red Gard then the tile.
https://www.custombuildingproducts.c...s/redgard.aspx
Old 05-12-18, 01:30 AM
Marq1's Avatar
Received 426 Votes on 397 Posts
If you want it done right do some googling for Ditra or Prova membrane systems, nothing better!
Old 05-12-18, 05:08 AM
P
Received 747 Votes on 686 Posts
Tile board and grout can be done with tile. It's a slightly old method that also requires a shower pan or EDPM membrane and and often with a tamped mortar floor. It works and has been the method of choice for 30+ years. But, It's more labor intensive and hence more expensive than more modern methods like Ditra sytems.
Old 05-12-18, 02:54 PM
czizzi's Avatar
Received 14 Votes on 12 Posts
Will there be a fiberglass or acrylic shower base installed and then tile on the walls? Or is this a build from scratch custom shower base/pan/tiled floor and tile on the wall?
Old 05-14-18, 02:17 PM
A
There are two layers of tile being removed on shower walls and will be replacing them.
Old 05-14-18, 05:10 PM
czizzi's Avatar
Thanks, but really didn't answer my question. What type of floor are you using, or are you just removing tile on the wall and trying to salvage? What is currently behind the wall tile?
Old 05-14-18, 05:14 PM
A
Sorry, the shower floor is cast iron tub and we are not moving that. I'm not sure what's behind the two layers of wall tiles. I assume wonderboard? We are removing both layers and replacing whatever board is behind them.
Old 05-14-18, 05:21 PM
A
Sorry, I didn't give enough details. So it's our shower walls. They have two layers of tile we are removing and replacing. We are planning on removing them down to the studs and replacing whatever wonderboards are behind tile. The shower bottom is our cast iron tub, which we are not moving.
Just to clarify, what is an appropriate material behind wall tile? Should it be studs>wonderboard>redguard>tile?
Old 05-21-18, 01:26 PM
H
Received 8 Votes on 8 Posts
Some clarification.
Ditra is an uncoupling membrane typically used on floors. Kerdi (another Schluter product) is a waterproofing membrane typically used in showers, on floors and walls.
EDPM is used in outdoor ponds, not showers. Shower pan liner is typically PVC.
