Tiling - Spacing between Tiles and Wall
Received 0 Votes
Hi,
**Please view the attached floor design
I am done with my powder room tile design. But before flooring the tiles, I want to confirm spacing between
1) Tiles
2) Tiles and Wall
3) Tiles and Transition
As of now, I designed with 1/8" (inch) space for above all. would this be ok?
Also do I need to leave space to allow expansion and contraction between transition and living area (wood flooring - marked '3' in the attachment)??
If I don't decide to have tiles on the wall, should it be ok to apply sealer between wall and the tiles?
1) Tiles
2) Tiles and Wall
Your good, no expansion consideration needed for tile.
You will probably be installing baseboards around the perimeter of the wall on top of the tile so no need to grout along the edge of the wall and tile!
Received 0 Votes
As mentioned by Marq, I did redesign my floor and realigned floor tiles without wall space. But some articles say wall spacing should be considered for floor tiling. Now I am confused?
Can you please assist? I don't want to realize the fact after flooring my tiles
Should wall spacing to be considered for tiles? I already did maintain wall spacing for my under-lament (plywood and ditra)
The reason you might space the tile away from the wall is how it might look once the baseboard is installed. Has more to do with where the grout lines are or size of the tile at the opposing wall than anything else.
Received 0 Votes
Thanks for ur response. Wall baseboard is already in place. It's a old bathroom. I am just replacing floor tiles and wall baseboards are already installed
When I mean wall spacing, I mean the spacing between the wall (baseboard) and edge tiles (As highlighted in the pic)
So you are going to have baseboard between the floor tiles and the wall tile? IMO when wall tiles are used it looks better to not have wood base. Either bring the wall tiles all the way down or use a matching ceramic base.
Received 0 Votes
Thanks for ur response. Either case, it could be matching tiles or baseboard, when flooring the tiles, should I need to leave the gap between the floor tiles and wall or not? (I mean between tiles and blue wall
I'm guessing that if you keep asking the same question over and over that the answer will be the same.
Here is what an industry standard says:
ANSI, under section A108.01, 2005-3.7 together with common industry practice, recommends expansion joints in tile installations at the following distances:Interior applications require joints at 24-32 feet on center. Exterior applications or interior in direct sunlight require joints at 8-12 feet on center.
Your room is interior and it is so small that it just doesn't matter either way. Technically, you should leave a gap. Either way, grouting the perimeter of the floor is unnecessary when it will be covered by a tile base.
Just for example... lets say the drywall is not between the tile and the framing. And your tile and grout is butting up tight against the bottom plate of the wall, which is wood. In that case, the reason you leave a gap around the floor tile has NOTHING to do with the tile expanding. (BTW, all matter expands and contracts with temperature and humidity changes... tile is no different.) You leave the expansion joint because you don't know how much the wood might expands if it gets wet.
