Removing sticky tile from concrete
Received 0 Votes
Having an issue getting sticky tile to come up off the ground. Some area is concrete and other areas are commercial grade tile. How do you get this stuff up without destroying your knees and back? Got 400 sq ft to pull up. I did start heating the tile and it slowly comes up but looking for better alternatives. And how do you remove the excess adhesive from the tiles after they are pulled? If I step in a spot I always lose my shoe.
There are powered tile scrapers made just for the task. Check with tool rental stores in your area to see if they have one you can rent. The money spent on a half day rental could be well worth it.
I have also had luck with a straight hoe. The garden tool. Sharpen the edge and it allows you to scrape while standing up and the extra mass/weight of the tool gives it more power when you slide it into the edge of the tile.
Use gloves, make sure a window is open.
