slate flooring
Old 05-25-01, 09:13 PM
Guest
I was looking into installing a slate floor in my bathroom, but there doesn't seem to be much information out that is specifically for slate. Is putting slate in the bathroom a bad idea? If so, why? How does it cut - like ceramic tile and with a ceramic tile cutter?
Thanks for any information!
Regina
Old 05-25-01, 10:34 PM
T
Received 1 Upvote on 1 Post
Installing slate floor
Proceed as you would with a tile installaton, using a diamond wet saw. Use concrete backer board for underlayment as you would for tile. To learn about the cleaning, sealing, and maintenance of your natural stone product, go to http://www.stonecare.com.
Old 05-26-01, 05:40 AM
Hi Regina,
Slate is a little tough to install. Like any rough cut stone, the peices are not all the same thickness. You compensate for this by building the thinner pieces up with additional thin set as you go.
You'll also find that the pieces are not all the same in their other two dimensions, and there will be variations in shade, color and texture. It's important to unpack all your pieces and spread them around before you begin.
And yes, all cuts are made with a diamond wet saw. Tile cutters won't work.
John
http://www.johnbridge.com
Old 05-26-01, 11:01 AM
Guest
Thanks for all the good tips & information! I have a wet cutting saw from doing stained glass windows, so I'll try using that on a sample tile to get the feel of how it cuts.
Regina
