Concrete Floors treatment
We live in a tidewater house in florida (built on pilings 8 years ago) with a concrete slab for the floor. It was previously tiled with ceramic 12" tiles which are now coming loose and popping up. We intend to remove the old 12" tiles and replace with 16 or 18" tiles. We removed 20 tiles which lifted off very easily with little or no residue left on the concrete floor. It appears that for some reason the tiles did not adhere properly to the concrete. We sprinkled water on the concrete to test for any type of bonding chemical and it was absorbed over several minutes. What would be the best foundation for the tile so that we can be assured it will not pop up due to movement, moisture or previous concrete chemical treatment? We prefer not to use wood since this is a termite area. Nancy
Not sure what the reason would be for your tile coming loose, but we've been having quite a discussion about bonding problems on other tile boards..check out this product at http://www.schluter.com/english/section-6.htm
Hi Nancy,
The delamination you have experienced is called "tenting," and there are a number of reasons it can occur, all of which seem to boil down to improper installation. The subfloor may not have been properly cleaned, the wrong adhesive might have been used, etc. Perhaps movement joints should have been provided.
Tell us the dimensions of your intended new installation. It is entirely possible to do a good installation over concrete -- if it's done right and the concrete is in good shape. Also, describe any cracking that might have occured.
John
John
Dear John, the dimensions of the first area are about 12 1/2'x 40', then shooting off that area is a 9x10 dining area and a kitchen area about 5x 15, then at the end of the 40' area is a hall 4'x13', the last 6' of the hall widen measures 6x6. On the same end of the 40' area on the opposite side where the hall begins, is a front entry that is 5x6. In the area where the actual tenting occurred (and it looked just like a tent), there was a very tiny hairline crack less than a half a millimeter wide. We put a level on the area and it seemed quite level. When you go under the house and inspect the concrete, there is virtually no cracking or sign of movement. When we pulled up the loose tiles there was a papery type membrane stuck on the bottom of the tiles. The concrete floor was astoundingly clean and had very little yellow colored stuff left on the floor. It was all stuck on the tiles.
Hi Nancy,
The yellow stuff may be part of the problem. It sounds like some sort of mastic or glue. Thin set mortar should have been used instead. The papery stuff (I don't know what it might be) doesn't belong there either.
The crack, since it doesn't go through the slab, is merely a "surface check" and wouldn't cause any problem.
A big problem is the lack of movement joints in a 40 foot span. There should have been at least one flexible grout joint and probably two.
Also, I think if you bang around over the entire floor, you'll discover more loose areas -- not necessarily "tented," but hollow sounding. Use the plastic handle of a screwdriver or something similar to tap on the tiles. The hollow areas will be easily apparent.
I hope Adanac or someone else will jump in at this point to give us their perspective. Then we can get down to the new installation (after you get all the old stuff up and out of the way, that is).
John
http://www.johnbridge.com
John
Is the yellow the same colour as the background on this web page? If so, then it's probably old oil base glue that they used many years ago. It eventually dries out, leaving no bond at all. I agree with John...40 ft is a long way without an expansion joint. Any chance of sending a picture of the tile and the yellow stuff?
Hey Jim,
Speaking of boards, you've been AWOL from our board for a while.
And speaking of cardboard, I found stips of tile boxes under the tiles in a shower one time. The guy had used them to pack out a ledge. It was a sheetrock shower anyway, but the cardboard added insult to injury.
John
John
