How to clean slate with milky paint residue
Old 12-19-19, 09:29 AM
T
Received 87 Upvotes on 77 Posts
We had painting done and some paint got on blue slate in our entranceway. It was cleaned before drying with water but a modest milky film remains. I've read about alcohol or mild dish detergent (Dawn) but have not tried anything. I also considered 1,000 grit sanding. I don't believe the slate is sealed.
Thoughts please on the way to remove it.
Old 12-19-19, 09:56 AM
XSleeper's Avatar
Received 1,720 Upvotes on 1,544 Posts
I'd probably use goof off on a clean cotton rag.
Old 12-19-19, 11:01 AM
Marq1's Avatar
Received 1,107 Upvotes on 1,007 Posts
So give the non-petroleum products first, then move up to the stronger cleaners if needed.
I would absolutely not use any type of sandpaper, the will ruin the finish!
Old 12-20-19, 03:37 AM
Received 742 Upvotes on 648 Posts
Denatured alcohol and products like 'goof off' and 'oops' will dissolve latex paints. You'll want to turn or replace the rag often.
Old 12-20-19, 07:36 PM
sam floor's Avatar
Received 30 Upvotes on 25 Posts
If you use sandpaper, the scratches will be permanent.
