Best way to handle soft drywall around shower
Old 01-20-20, 08:43 PM
Hi!
I have some soft drywall above my shower insert, around the rim. It is no thicker than my pinky, so I dont believe it goes above the part of the insert behind the drywall (I believe the drywall is on top of the insert but I could be off)
My question is, is there anyway to fix this beyond cutting above the shower insert and adding new drywall?
Image: https://imgur.com/gallery/e1KZvmx
Old 01-20-20, 08:51 PM
XSleeper's Avatar
Received 302 Votes on 275 Posts
Cut out anything that is soft and replace it with setting compound. Drywall and joint compound get soft when they get wet. Setting compound does not.
Old 01-20-20, 08:54 PM
Thanks. So. I'd have to cut out and replace the drywall or just cut the thin piece of drywall and replace with the setting compound?
Old 01-20-20, 08:55 PM
XSleeper's Avatar
Whatever is soft. If 3/8" is soft, cut out 3/8.
Old 01-20-20, 09:02 PM
Got it. I guess I'm wondering if the compound can fill the gap if it is about 1/4inch without replacing the drywall that was cut out. If that makes sense? If not if have to cut out a lot more drywall to catch a stud above the insert.
Old 01-20-20, 09:40 PM
XSleeper's Avatar
I must have missed something. Where did I mention replacing any drywall? Cut out what is soft and use setting compound!
Old 01-21-20, 03:15 AM
Received 168 Votes on 149 Posts
Setting compound isn't water soluble and won't shrink unlike regular joint compound. Once finished/dry caulk the top of the surround to the wall.
Old 01-21-20, 03:31 AM
Awesome thanks both! Sorry for the confusion
Old 01-21-20, 08:56 AM
Silly question, but is there an easy way to find setting compound that is not joint compound? Not glaringly obvious on home depot or lowes websites.
Old 01-21-20, 10:09 AM
Regular joint compound comes in buckets - premixed. Setting compounds are powder that comes in a bag. You mix up what you need and discard any mixed mud as it starts to set up. Durabond and EasySand are the 2 main brands but there are other brands also. The number behind the name [like Durabond 20] denotes the approximate work time. 45 minute and 90 minute are probably the most popular.
https://www.lowes.com/pd/SHEETROCK-B...mpound/3009547
Old 01-21-20, 11:51 AM
Awesome. Thanks again! Very much appreciate it
Old 01-21-20, 07:31 PM
XSleeper's Avatar
Except I'd probably be using the Easy Sand that Marksr mentioned. https://www.lowes.com/pd/ProForm-Qui...mpound/3182361
Durabond works well but it's almost impossible to sand. The product I linked to could be used for all 3 coats. You might even do it in two. If a third coat is needed, a very thin skim coat of joint compound works well before paint and primer.
Old 01-27-20, 09:05 AM
Thanks again to you both. I cut out the soft spots and used the joint compound. Once I got the consistency down it went on real smooth, I barely need to sand. Really appreciate it!
Old 01-27-20, 09:39 AM
Thanks for the update, glad it worked out for you!
