1/4" hardibacker over 1/2" ply sub floor for tile?
Redoing my bathroom. It's a 1966 house and the sub floor is 1/2" ply, some of which was rotted out. I'm replacing the whole sub floor just for posterity. As it was 1/2", I'm going to be using 1/2" again. I had the choice of 3 ply or 4 ply, of which I chose 3 ply as it was cheaper - is that ok?
I'll be tiling the floor and planned on doing a standard tile job: Paper > thinset > 1/4" hardibacker(screwed) > thinset > tile.
Will that be legit, given the subfloor is substandard thickness?
You should be replacing it with a minimum of 3/4" plywood. You shouldnt even attempt to put tile on a substandard subfloor. Its just asking for problems.
All joints in the ply need to be supported. Tongue and groove plywood or Advantech would be best but if using regular ply you can install blocking under the seams and screw them together. Basically tongue and groove is a lot easier especially if doing a decent sized space.
