[Tiling] - can I run my backerboard just to the top of the tub flange?
I'm wondering if it's acceptable to run my hardibacker only to the top of the tub flange, and obviously the tile will come down closer to the tub. Seems like if I run the backer board over the flange, it will bow outwards. Also I thought about notching out the back of the hardi where it would go over the flange so it doesn't bow.
thoughts?
thoughts?
You want a membrane to cover the flange. Some guys use window flashing tape, such as ProtectoWrap. Then you set the backer board on top of the flange.
survivalbloke
voted this post useful.
If that's what you want to use. There are several schools of thought. Poly behind backer board is one.
But I don't do it. A professional tile layer in Omaha that I know and respect (we often work in multi-million dollar homes) says that the backer board needs to be able to dry out if it gets wet or it leads to mold and grout failure. So I subscribe to the method that puts no vapor barrier behind the backer board, and instead I put a liquid membrane (Redguard) on TOP of the backer board. That keeps the backer board dry, and if it does happen to ever get wet, it can dry to the back side. So if I was doing it, I would just flash the tub flange with ProtectoWrap, then set the backer board on top of the flange.
survivalbloke
